C cab on a t frame?
Ryan
How big of a deal would it be to mount a C-Cab onto a T frame? I really like the c-cab, but have already gotten the frame just about welded up. Any ideas?
It depends on what body you buy/build. Meangreen built both of his C-cabs on T frames. The rear of the frame past the kick up was just a little longer to support the back of the body. His wheelbase was only 96 inches.
  • Like
Reactions: RPM
That sounds simple enough. I'm also using the awesome "Youngster" plan, which is 101"
I'll have to look up MEANGREEN to check it out.
Thanks
If you want the truck C-Cab body it will fit onto a '23 tbucket frame. Our delivery frame has a longer kick up in the rear to support the frame. Off the top of my head I think the wheelbase for our delivery is around 112".
Does this mean you folks do more than one length C-Cab body?
