One of the open issues in my mind is the upper front shock mounts. I've not found any "off the shelf" units that will work. I will be using a front suspension configuration similar to this...
only with the lower shock mount pointing to the inside rear. The axle I'll be using is a 48" king pin width, with the spring perches 36-3/8" on center. This will put the lower shock mounts around 3-4" outboard of the frame.
With this set-up, as the caster angle is changed, the angle of the shocks...and their upper mounting point will also change. Without the upper mounting point changing, it seems to me binding would result. But I've yet to see an adjustable upper shock mount for these cars.
When configuring the front shock mounts, is it just a matter of settling for a happy medium for the shock/caster angle? If so, what angle is a good happy medium angle?
