You WILL!! go out of control and wreck.The front wheels will start to bounce bad and you will loose all control of your car.Now there are some here who will disagree but i have gone down that road with bad friction shocks and it went away with hydraulic shocks.Do as you want but consider this a warning.Is it possible to go without shock on the front of t buckets? I have ssen some that looks like there is none on them. What would be the drawbacks besides a stiff ride?
Sure. I've been driving mine for 15 years without shocks. It's fine around town, and I cruise on the expressways and interstates at 60mph. The only time it is a problem is on bad roads; then the wheels will bounce some.
As others have said, shocks are definately necessary for safe, fun driving. I am a fan of coil-over shocks as you can eliminate the buggy spring and they have some adjustability and the springs can be swapped out from different rates if needed. The down side is that they are bigger and need to be designed with the frame upfront for a strong clean design. With that being, said, in our current budget '23 build, I'm not sure yet about the front shocks. I'm leaning toward a mount like others have shown and use a smallish shock and a buggy spring...I'll be looking at some of the mounts and ideas in this thread.
this is what Ben T has now another good option gives a little more modern look.
Sorry if I posted the wrong picHere is a better shot after completion. The shock are not as visable with the grill shell and headleghts on. I've been able to fine tune the front end a biot with the shocks and it rides great!
Hmmm, great discussion. I was planning on going with friction shocks for an old school look but I'm going to rethink this because we do have bad roads around here. Good to see a wide selection of shock mount pics
