Welcome to Our Community
Sign Up
Dismiss Notice
Driveshaft length
Discussion in 'Engines and Drivelines' started by Snicklefritz, Apr 10, 2022.
  1. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    you may be right but if there is a guideline or limit to the length i'd rather know it now than after everything is in for good. where i put the body is partly determined by where the drivetrain goes and where the drivetrain goes may be partly determined by a minimum safe length of driveshaft.
  2. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    this is? i couldn't find anything on this particular subject.
  3. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,509
    772
    Gender:
    Male
    Occupation:
    Retired
    That's true Spanky. You don't need the drive shaft unless you're planning on going somewhere!
    Spanky likes this.
  4. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,509
    772
    Gender:
    Male
    Occupation:
    Retired
    Snicklefritz, I've never experienced a problem with it being too short. I'm still talking drive shafts here! How much space is there between the end of the tail shaft and the rear end yoke? I just went and measured my drive shaft. It is about 9" u joint to u joint. I suppose if there was a really short distance between the trans and the rear end, it might put undue stress on the u joints due to the extreme angle.
  5. Snicklefritz
    Snicklefritz
    Expand Collapse
    Aug 6, 2018
    268
    91
    Gender:
    Male
    that's the thing. the engine/trans and rearend are not in fixed spots yet. there are a few things up in the air at the moment: still waiting for parts from ron, still trying to sort an unresolved mess up with the motor mounts, and exact location of the body i've yet to determine. i think in the end all will be well it's just i like knowing certain things beforehand.
  6. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,722
    932
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
    Look this up.
    � DRIVE LINE PHASING AND UNIVERSAL JOINT ANGLES BY JOHN NIOLON � Engine, drive line or rear suspension changes sometimes move things...
    lincolnuT and Snicklefritz like this.
Share This Page
SSL Certificate
