Oldbuilder
Okay folks,,, this has probably been asked a 100 times but instead of spending hours combing thru the posts I'll start fresh. Starting to install the floor and need some fiberglass questions answered please. I've started with pad you can buy at the local parts store, Bondo is the manufacture.
1. What ounce weight glass should be used? The parts store product doesn't tell you this.
2. Mat or cloth? I've started with cloth,,,
3. Does it take more than one layer to be strong enough on the floor edges or should I lay extra?
I've glassed both top and bottom so far.
4. How long is normal for the resin to setup and/or cure? Is that two questions???
