I took it out for the first time today i went about 4 miles just for a check out. I had very little trouble with it, first off i had the transmission vaccume line on the wrong port of the edelebrock so it wouldn't shift into high gear. then i noticed a small leak of ATF from one of the double flairs going into the trans cooler. Other than that it drove very straight and easy. The brakes stopped real good, the engine didn't overheat even though it almost 100 degrees here today. All gauges worked properly. I'm pretty satisfyed for the first time out. I did get plenty of thumbs from the neighbors, my gardener even went along for the ride. I'm still waiting on the chrome shop to finish the door hinges to install the door then that will allow me to finish the upholstery.
