You've got to remember....your not pushing nowhere near the weight of a normal car.....1600-1800 if its a bit on the chunky side. Well....since we're all performance folks here....he's something for comparison.
Get a Econo-Altered...basically a T, put a stock smallblock chevy in it, a powerglide, and about some 4.56's to 4.88's in the rear....and if she's hooking at all, she'll be running about mid to hi 10's @ about 135 mph. Nothing fancy or magical, its just your not pushing any weight at all and with those gears....the motor winds agianst the only resistance, thats the gearing.
Same thing with a BBC and a T. Theres alot of guys here that run them, with tunnelrams, blowers, nitrious, maybe both!....do they need it, no. They could easily run in the 10's, and if they were hooking good, probably 9's, with a good tuner on hand.
With a BBC thats healthy, I myself wouldn't run anything lower than a 3.50 or a 3.55 rear gear, and thats with the tallest rear tires you can find to put out back. Anything lower, when you step on it hard, it isn't gonna move, its just gonna spin.
Big power in a light car, go with a taller gear (numerically lower number)....
I don't think you want to run a spool, its your car though. Its gonna try to 'push' thru the corners, its gonna try and 'crab'when turn a sharp corner. Limited slip would be plenty, or a bonafid posi-trac....
With a spool, you'll get into a lot of undue tire wear....if you put anymiles on it what-so-ever....
