This sale did so well before, we thought we would do it again.
FREE yes a FREE 23 traditional glass body. Simply purchase an RPM rolling frame kit, and receive a FREE body to go along with it.
The rolling chassis kit comes with:
The perimiter frame with all the steering and suspension brackets, welded on in our precision frame jig.
Engine and trans frame brackets welded in place.
4” drop tube front axle.
New spindles, with king pins and bushings, installed and fit.
Front and rear radius rods. 1” on the OD not wimpy 7/8” stuff!
Front spring with shackles and pivot kits.
Complete front disc brake kit.
Tie rod assy, drag link assy, panhard kit assy.
A brand new Vega steering box, and pitman arm.
Chrome QA-1 coil over shocks.
Rear shock and radius rod axle brackets.
Necessary Heims, Clevis, nuts and bolts.
The rear axle brackets will be welded to a “USED” s-10 rear end. Set up so it will bolt into the frame. There is NO WARRANTY on the rear end.
Ready for you to mock up.
Also a FREE BODY.
For just a $300 up charge we can do the 10" stretch body kit.
All for only $2995.00 plus shipping and handling. Sale ends 10-31-13
Half down to order and the balance when ready to ship. Shipping runs about $300- $400 depending on where you are.
Also a FREE BODY.
