I want to remove the front axle to get it painted or powder coated. The previous owner really banged it up so it's another item due to be refinished. Have never done this before so I have a few questions.:
1. How do I pull the kingpins? I can see a bolt through the axle and partially into the side of each king pin, if I remove that bolt is there something else that needs to be undone to remove the kingpin?
2. If the car is up on jackstands can I just unbolt the shackles from the axle or do I need to be concerned about preload on the springs?
3. The part the shackle bolts to (name?) goes through the top of the axle and there is a nut on the bottom so I assume I can just remove the nut and pull it out of the axle?
Bruce
This is something many of you have done before so apologies for the newbee-isms.
Here are a couple of photos:
Bruce
