Not fixing to at lest some amount ackerman is just as dum as no front brakes at all. Yes I know there some that even think that's OK,very sad!
For those that seem to think your rod handles OK with backword ackerman,your kidding you self to the point of a crash to come. What I posted is the real facts,if you are turly that spaced out about how your rod works,I can not help ya.
I've designed & built more rods then many of ya,and many many more race cars.
A T--buckket has a lite front wheel load,and that makes bad engineering even more dangers because when the only one front tire that's working at all from that bad no ackermen, lets go of the road you totaly lost,the other tire was already not doing any thing helpfull.
Understand for those who are thinking it's OK,but that it is not.
Yes ,you can go in a strait line just fine,but in a turn,the inside tire starts to go much straiter then the out side tire that is trying to turn your rod,so there fighting each other instead of helping,giving the rod less then even one tire steering the rod. Try to keep in mind that this happens more the sharper the turn is=most likely the full skid happens at the time you needed to steer the most.
Go a head an keep fooling you self. Get in the crash and you can fine out the hard way.
Fixing the arms to at lest strait out from kingpin is much better then not doing anything,but still short of having it right.
Rods are fun,but don't need to be poorly engineered.
