Good morning,
I picked up some 3/8" aluminum fuel line to run from the tank along the frame rail to where the soft line will connect to the mechanical fuel pump on the engine. I'm wondering if it is too small, it nets out at 1/4" inside dia. I'm running a bored 283 NA with a single carb, mild cam with no electric pump, the fuel will gravity feed from the tank to the mechanical pump. I'm inclined to go with 1/2" that will net 3/8" ID, I know that will do whatever I need. Just thinking out loud here, any opinions??
Thanks in advance,
Steve
Thanks in advance,
Steve
