After getting the car to loaded ride height, I'm seeing that I only have about 2-1/2" clearance between the steering box and the ground. Under normal conditions I don't think I would have a problem as long as I avoided speed bumps, but a crown or rise in a driveway may be an issue. I double checked and if I get a flat on that side, the box is still at least an inch off the ground. What is your experience? Cutting the bracket off and re-welding it will be a pita...
I have about 3-1/2" to the oil pan, so I think I'm good there.
