I'm moving on to my mock up stage and starting with the rear,(why cause thats what parts I have already..LOL) I'm using the High arch rear spring from speedway,(THANK'S AL !!!)
and I'm mounting it to a S-10 4wd rear-end with this the Model A/T spring mount.... My question is what is the best way to figure out where to mount the brackets to the rear? I know I need atleast 4to 5 degree's tilt in my diff. and that the shackles should be at 10 o'clock and 4 o'clock when at rest(or atleast thats what I have read and seen on various cars and done in the past). has anybody used this type set up before around here, and if so where and how far in from the backing plate did you mount them? Or can somebody point me in the right direction before I screw this up.. Also any tip's on welding these up to the rear, with out warping it.. I've welded spring perch's on my 68 Road runner before and never had a problem(or atleast I don't think I did.....)So O'WISE BUCKET HEAD'S I GIVE THIS QUESTION TO YOU, IN HOPE'S YOU CAN SHED SOME OF YOUR ALMIGHTY WISDOM DOWN UPON ME.....Thank's Ryan.. Also who sell's the Spring U-Bolts and bracket for this spring to mount up to a Model A crossmember..
