baddawgcustoms
One of the first goals for my build was to get the car as low as possible. Nothing on the car will be below the frame rails. As the car sits now I have 5" ground to frame up front and 7" in the back. I'm toying with the idea of going down one more inch to 4 and 6. At 4" and 6" my wheels with no tires will barely touch the ground before the frame so my scub line is fine even that low. I remember exjunk saying his oil pan was only about 3 1/2" from the ground and has never had an issue. (Wheel base is about 112 with the stretch body). Since everything is above the frame rails, I don't think it would be a problem. Both front and rear suspension. Is adjustable in height, so it would be fairly easy to pick it back up a couple inches if I needed to do so, and would not have to do much but adjust pinion angle on the 4 link, caster in the front, and the front of the 4 link which will also have adjustment for height. Just curious as to your opinions.
