I am going to stretch a bucket body 30-36". What would be a good way to go about it?
Have you figured out where you want or need the stretch? Are you building your car now and have the option of stretching the chassis too? I have seen guys cut the body at the cowl and add length there. As for the process, there are like a number of ways to go about it like most things. I will assume that you are not looking to build a mold of the body by using your current body as a plug, correct? This being the case, you will be working with the finished product throughout the process. All of this work should take place on a sturdy surface that permits full access to the areas of the work. When you start cutting, things can move, so you need to keep this in mind.
Once you decide where to cut, cover the areas that you will layout with masking tape. This permits a easy surface to mark on and if you make a mistake, use an eraser or replace the tape and layout again. When you are satisfied with the layout, PUT ON PROTECTIVE CLOTHING, PROPER MASK & SAFETY GLASSES. This means cover all of your exposed skin, wear gloves (I typically tape my gloves to a long sleeve shirt at the cuffs), dust mask, glasses, etc.
Using a pneumatic cut off wheel, or a small electric grinder with a slim cut off wheel carefully cut along the marks that you had made separating the two areas completely. Now the fun, you will need to carefully align the two pieces leaving the 6" gap that you are seeking. Once you have accomplished this, use some furring strips (1" x 2") wood and brace the parts as you see fit to hold everything aligned. You can simply drill small holes through the body wherever you need a brace and then put a temporary screw through the glass body into the wood. The bottom line here is that you need to keep anything from moving at all. Any flex now could spell disaster as the new glass layers heat up during curing and pull things where you don't want them.
Okay, now that everything is braced exactly where you want it, use an angle grinder with 24 or 36 grit paper and go around the entire cut back several inches from the cut line and grind the existing surfaces through most of the thickness leaving between 1/16" and 1/8". Once this is completed, you will need to be a bit of an artist by covering the opening from the inside with various materials to create a temp backing and depending the shape needed will determing what you use to back it. If the surface is a simple curve, mica (the counter top version) works well. You can tape it well to the inside of the glass surface. Also, if you can use a smooth backing like mica, apply a couple of coats of mold release wax prior to putting the pieces in place. This will make them very easy to remove from the inside when you are done. If the surface is parabolic (curving in two directions) you can use pre shaped urathane foam arrached to the inside. You can also use aluminum duct tape, thin wood, plastic, or most anything else that will give you a suitable backing. Remember here that the backing is only temporary and does not need to look pretty, just be the correct shape.
Okay now the fun part. Depending upon the total thickness that you need to make up, use a combination of matt and cloth (mat is muntidirectional strands of glass and cloth looks like fabric). Pre cut the matt and cloth to fit the opening including the area that laps over onto the existing glass so that you dont have to fiddle with this during the process of applying resin. In a well ventilated area with freah air, mix up your polyester resin with the MEK (hardner) as per the instructions provided withthe resin, which can be adjusted depending upon your air temp. Colder air makes for a slower cure, etc.
With a throw away paint brush, apply the resin directly onto the backing surface and onto the previously ground body, with your gloves on, place your first piece of mat over the wet resin and then begin to apply resin on top of the mat. This is called the wetting process and if done correctly is pretty easy. When you brush the resin, the goal is not to drag the brush, but rather to apply as much resin as the brish will hold and wet the mat dipping the brish frequently. Since the resin will set up in the bucket within about 10 -15 minutes depending upon temperature, only mix and apply as mucj as you believe that you can get done, but always enough to wet out the mat that you are working on. Once the mat is wet which you can tell by it turning from white to almost translucent, begin to use your resin roller to gently remove all of the trapped air bubbles. Use a light to see this properly since theis will be structural and bubbles are the enemy. Now continue this same process over and over until you have reached the desired thickness. There is no need to wait for the first or intermediate layers to set up and feel free to build it out to full thickness. Since you will be sanding the finished glass work add styrene (surfacing wax) to the very last mix of resin when you apply the last layer of mat/cloth. This will eliminate the sticky finished product and will permit sanding without gulling up.
Well, this is the basic info needed and I do suggest that if you have never done this type of thing that you mix up some resin and try a small project first.
Good luck..
