Welcome to Our Community
Sign Up
Dismiss Notice
In need of Help..
Discussion in 'Brakes' started by Space Coast Rodder, Dec 28, 2018.
  1. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    If I'm seeing correctly , that looks like a GM pinion snout , if that's the case then someone left out the self adjusters , the other observation is that those adjusters are really cranked out , maybe drum ground oversize ??
  2. Space Coast Rodder
    Space Coast Rodder
    Expand Collapse
    Dec 13, 2018
    118
    16
    Gender:
    Male
    With some parts installed wrong & some parts missing it makes me want to convert to disc even more..
  3. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    The lack of a proportioning valve wouldn’t cause the hard petal issue that you described. I would think that is caused by incorrect petal ratio, incorrect master bore, pinched line, maybe residual valve installed backwards, but that’s a stretch. Be sure the mc is plumbed to the correct axles. I would inspect and adjust everything, be sure you have good fluid flow to the wheel cylinders and calipers, paying particular attention to the petal ratio first, then the mc bore size. Once you get acceptable petal reaction and feedback, you can do some test hard stops to determine if the bias needs addressing. Some guys don’t use any proportioning valves, some install adjustable on the fronts, some on the rears... it depends on your particular build. Your parts should have part numbers on them, the internet might help identify your components. If you have to swap the master, it’s not a very expensive piece, so even if after swapping it you decided to go a different route, you shouldn’t be out too much... these things are never finished anyways! Hobby!
    lincolnuT likes this.
  4. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
  5. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,509
    772
    Gender:
    Male
    Occupation:
    Retired
    That's the truth. Never finished. If it was, what would you do tomorrow?
    lincolnuT and Driver50x like this.
  6. Space Coast Rodder
    Space Coast Rodder
    Expand Collapse
    Dec 13, 2018
    118
    16
    Gender:
    Male
    I'll find out the pedal ratio today & if that's ok I'll pull the master cylinder later in the week & go from there.. I already checked for a pinched pipe and didn't find a problem..
  7. Driver50x
    Driver50x
    Expand Collapse
    Aug 8, 2016
    55
    40
    Gender:
    Male
    Occupation:
    Pilot
    The missing adjuster hardware is nothing but a minor issue. You can adjust the brakes by hand anyway. You can buy the adjusters at any auto parts store if you want them. Your springs are installed correctly. You really need to measure your master cylinder piston size. As others have said, that could very likely be your problem. Even on a car as light as a T-Bucket, the cylinder sizes make a big difference. You can probably measure it without removing it from the car, depending on how it is mounted. Just pull back the rubber seal and use a tape measure.
  8. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,509
    772
    Gender:
    Male
    Occupation:
    Retired
    DFriver50X, it was my understanding that the coiled part of the spring goes over the star wheel to help hold it in adjustment.
    When there is an adjuster, like what Choppedtop showed, the spring is installed with the coil away from the star wheel. But when there is no adjuster mechanism the spring goes the with the coils over the star wheel.
    Just sayin'.
  9. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,933
    637
    Gender:
    Male
    Occupation:
    Retired
    Yeppers, something has got to make contact with the star wheel. If not adjustments would not stay to the proper tightness.
    Neshkoro and lincolnuT like this.
  10. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,509
    772
    Gender:
    Male
    Occupation:
    Retired
    Chopped, that was my thought.
  11. Driver50x
    Driver50x
    Expand Collapse
    Aug 8, 2016
    55
    40
    Gender:
    Male
    Occupation:
    Pilot
    Gotcha. I was just thinking about the way they come from the factory.
  12. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,722
    932
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
    Go to Advance Auto and find the Help section. They should have what you need. Left and right. .
  13. HenrysT
    HenrysT
    Expand Collapse
    Mar 12, 2012
    599
    227
    Gender:
    Male
    Occupation:
    Carpenter
    Did the "Tri Fives" have self-adjusting brakes? Is it a Chevy RR or a 8 3/4" Mopar? What's the wheel bolt pattern? Can you take a pic of the pumpkin?
  14. Jim B
    Jim B
    Expand Collapse
    Sep 14, 2018
    402
    279
    Gender:
    Male
    Occupation:
    Retired.
    2old- I already have a complete rear end with discs ready to go. Why would rear drum brakes improve braking performance over disc brakes?
  15. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,239
    1,197
    Gender:
    Male
    Occupation:
    Retired
    Takes more pressure to make disk brakes work.
  16. Jim B
    Jim B
    Expand Collapse
    Sep 14, 2018
    402
    279
    Gender:
    Male
    Occupation:
    Retired.
    gotcha! good point.
  17. HenrysT
    HenrysT
    Expand Collapse
    Mar 12, 2012
    599
    227
    Gender:
    Male
    Occupation:
    Carpenter
    [​IMG]
    Space Coast Rodder likes this.
  18. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    486
    Gender:
    Male
    Occupation:
    sorta retired
    Tri five did not have self adjusting , that started about 63 ??
    Another point about drums vs. disc is the E brake , it's self-contained on drums ,looks like some add on most discs ..
  19. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,509
    772
    Gender:
    Male
    Occupation:
    Retired
    Either disc or drum brakes are more than adequate to stop your bucket as long as everything is working correctly. Working correctly is the key. Disc brakes have some advantages over drums. For instance: brake fade, wet operation. Discs have the cool factor. Drums are old technology Its like having a distributor with points vs. an electronic distributor. Either one will do the job.
  20. Space Coast Rodder
    Space Coast Rodder
    Expand Collapse
    Dec 13, 2018
    118
    16
    Gender:
    Male
    I'll be changing to discs soon, I prefer the look of them by far.. Haven't made much progress over the last few days, I can't seem to shake the bug I got & I just don't feel like working on the car.. Hopefully this will clear up soon Then I can get into sorting all this out.. Many thanks to everyone who's been helping along the way..
Share This Page
SSL Certificate
