Thanks I will check that out, I buy alot from them. The right tire is leaning in 3/4", I shimed all I could so I think the coil overs are bad. The T has not been on the road since 1980.I don't know what you consider "reasonably affordable," but I used the Carreras from Speedway, about $140 each.
http://www.speedwaymotors.com/Carrera-Street-Rod-Rear-Coil-overs,36586.html?parentDisplayId=1207
Will do, do you know about the correct size of photos you can post?Could you post a pic from the rear of your T? There are several possibile explanations for your camber to be out that far, and a pic might help us diagnose.
You can upload to Photobucket or Flickr, then link to the photo using the "Insert/edit image" button in the "Post Reply" window. The photo will automatically be resized to fit in the post.Will do, do you know about the correct size of photos you can post?
You can upload to Photobucket or Flickr, then link to the photo using the "Insert/edit image" button in the "Post Reply" window. The photo will automatically be resized to fit in the post.[/quote
Thanks Lee for the postHere are Jimmy's pix.
Yes it is an E-type 3.8 series 1, this has set in a barn for over 25 years, soAnother issue I see is it looks like you have nylocks on the studs for the inboard end of the half shaft. The heat from the brake rotors is going to melt those nylocks, if they haven't already. You're supposed to use mechanically locking nuts on those studs... the kind that are necked down at the outboard end. I stripped two studs with those stupid nuts, so I switched to normal nuts with split washers. I check them for tightness before every cruise, and they have never come loose. You can see the nuts and washers in the following pic. You can also see that I had to use six .030 shims to get my camber right. I can't tell how many shims you have from your pix, but if you get rid of the nylocks, you will have another 1/8" or 3/16" of stud threads to use, and you could add a couple more shims.
