s19243h
need you guys advice on getting the right cam. I have a 72 chevy 350 bored 30 over flat top 4 valve relief pistons stock 2 bolt bottom end with about 4000 miles on it it has 186 double hump heads 64cc ,screw in studs and push rod guide plates .im planning on putting an edelbrock streetram and 2 elde 500 on progressive linkage, yea I know ,it wont run on the street , don't try to talk me oit of it im going to try anyway.any how my bucket has a jegs 10" converter 27-3000 stall 350 turbo, 3:80 gears and 31" tall tires. I had a 305 in the car for 3 years before it got tired . the 305 had a e922p cam in it 214/224 dur,443/465 lift 107 ls when I put the car in gear the car would hardly move and the idle wouldn't drop that was the perfect stall for me . im afraid of loosing the stall by picking a cam that's to big for the 355. need advise thinking isky 280 mega or 270, comp magnum 270 or 280,or summit 232/234,488 all cams are108 ls ecept comp at 110
