I had someone run the brake lines for my T-Bucket but the brakes do not grab unless I pump the brake pedal. The installer swears all air is out of the lines but he has no experience with Hot Rods.
4 Wheel Wilwood disc brakes (4 piston fronts/2 piston rears), 2 psi Wilwood residual valves, Speedway 1" bore Master Cylinder/pedal assembly.
Any idea what may be the issue?
On T-Buckets do you bleed passenger front first?
