engine24355
Need some advice on an oil pressure concern I have on a new (less than 500 miles) vortec 305. The engine has a mechanical Sunpro (cheap) gauage which reads between 40-45 psi on startup and idle which does not scare me. However, when the engine warms up it seems to slowly drop. Also, as with mechanical gauges, the higher the rpm's the higher the psi, but when the rpm's come back down to idle the gauge reads lower and lower....big swing from high rpm's to idle. I have checked the line and fittings...fixed a leak and still reading same. My biggest concern is that the oil pump is not working properly, but would not think it would be bad on a new engine. At the same time, I have seen some really weird stuff over the years. Been thinking of switching to an electronic gauge or at least putting a pressure tester on it. Any thoughts / advice?
