I recently bought a steering box/ pttman arm/ bracket combo for my car, that I was not even impressed with. And see it as a potentially dangerous set up, and wanted to warn you guys. I use vega boxes mounted under the frame. In the past I have used Flaming river vega boxes. Well they are kinda pricey, so I thought I would try and save a few dollars, and I bought one of the repop vega boxes in a kit with a pittman arm and mounting bracket. Well the pittman arm did not fit right. It went on about 1/3 of the way (1/3 of the arms thickness went on). Enough to get the nut on, but no lock washer. I called the company I bought it from, and they sent me a picture of how it should look when installed. Here is that picture...
Supposedly that is how it should look tightened up. Notice the nut is right at the end of the threads, and no lock washer. Now look at this pic I took of my parts. With the nut on as far as thiers, see how much of the shaft would be in the arm...
Not near enough. To add to this, that arm is very soft. I took a small fine file to the back side in one of the splines and pulled on it, and it cut very easy. So you take a soft arm, that barely goes on, with those small splines.... and you are asking for stripped splines.
Today I went to summit racing and picked up a flaming river arm, to see how it fit. And big suprise... it fit properly. here is a pic of the flaming river arm on the other guys box...
and thier arm on thier box...
notice the hammer in the pic. I put a piece of aluminum on the arm, and tapped it on. That is as far as it goes.
Earlier this year, there was some talk about some pittman arms failing. I believe donsrods had an issue. IIRC they were from total perf, and supposedly they quit selling them. Well the chinese plant that made them, probably didnt stop making them... So you guys out there be carefull with what you use on your cars.
And I just want to note, this is not from Speedway. I found this on web, from a street rod mail order house. Is Speedways kit the same ? IDK, but I will bet there isnt a lot of different aftermarket vega arm manufactures out there.
