Corley
Anyone know if there is a removable pin behind the modulator valve on a PowerGlide trans? I'm trying to collect all the parts I need, but the PG is burried behind several other things and it is difficult / impossible to see in the hole. The modulator MAY just push directly on the valve, but I know some trans use a short pin. I'm sure if there is supposed to be a pin it is lost, as this trans has been kicking around for a while. I can't seem to locate a blowup pix, so any info or referance is greatly appreciated.
