Welcome to Our Community
Sign Up
Dismiss Notice
proportioning valve
Discussion in 'Brakes' started by rubicon, Jul 9, 2016.
  1. rubicon
    rubicon
    Expand Collapse
    May 28, 2007
    859
    254
    Gender:
    Male
    Adjusting the proportioning valve. Where do you start and which direction pinches off the rear brakes? Do you want the front or back brakes to grab first? I have a CCR frame and brake set up. Disc all around.
  2. tfeverfred
    tfeverfred
    Expand Collapse
    May 26, 2007
    5,058
    582
    Gender:
    Male
    Occupation:
    Receiving Clerk
  3. rubicon
    rubicon
    Expand Collapse
    May 28, 2007
    859
    254
    Gender:
    Male
    Thanks. I believe that answers my questions. I think most of the boys are at the nationals. Wish I was.
  4. tfeverfred
    tfeverfred
    Expand Collapse
    May 26, 2007
    5,058
    582
    Gender:
    Male
    Occupation:
    Receiving Clerk
    There's a good possibility, you may not even need one. The same goes for residual valves. With a low mounted master cylinder and your calipers only a few inches above your fluid level, you may not need either of those. I didn't have them on my T Bucket and she stopped on a dime, with a great pedal. Just something to think about.
  5. ellis8500
    ellis8500
    Expand Collapse
    Nov 24, 2009
    958
    77
    Gender:
    Male
    Occupation:
    Engineer
    I do not have a proportioning nor do I need one. The front calipers have larger pistons than the rears. This results in differential braking. Also have a manual, 4-wheel disc MC designed for mid 70's Corvette. Combined they provide the proper combination to eliminate the need for a proportioning valve. Car stops very well with no rear wheel lockup.
  6. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    I ordered both, they weren't expensive, and I liked the adjustability option.
  7. bamabucket
    bamabucket
    Expand Collapse
    Jul 27, 2009
    114
    41
    Gender:
    Male
    Occupation:
    Retired
    I recently reworked my entire brake system and did install residual valves and proportioning valve. I have 4-wheel drums and don't need the prop vale now but put it in so I would be ready when I go to front disks in the future. I have ready many posts on different forums regarding needing or not needing residual valves but I put them in anyway. The system works well (considering it is all drums). I'm not sure it is better now than before when it didn't have the residual valves.
  8. T-Test
    T-Test
    Expand Collapse
    Feb 6, 2009
    1,722
    932
    Gender:
    Male
    Occupation:
    Machinist/Welder/Mechanic
    Sue it is, YOU did it right and left the door open for improvements!!!
  9. bamabucket
    bamabucket
    Expand Collapse
    Jul 27, 2009
    114
    41
    Gender:
    Male
    Occupation:
    Retired
    Thanks Bruce - I consider that a verification and compliment.
  10. tbucketlar1
    tbucketlar1
    Expand Collapse
    Jul 2, 2016
    35
    0
    Gender:
    Male
    Nice post
  11. Spanky
    Expand Collapse
    Jul 29, 2016
    3,088
    2,530
    Gender:
    Male
    I found that with front discs and rear drums on my bucket, I needed the proportioning valve. Much better now!
  12. lincolnuT
    lincolnuT
    Expand Collapse
    Mar 21, 2008
    1,835
    485
    Gender:
    Male
    Occupation:
    Retired
    I do not have those in the bucket and I just don't see why you need them.......If you keep you drum brakes adjusted then they will work fine with front disc.......and if you keep the drums adjusted right you will be fine with them all around.....If you don't have any air in the system the fluid will stay where it is & ready to work anytime you step on the pedal..........That is my .02........ it may not be worth that much to you but works for me.....
    Mike
  13. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    The reason for them is if the master cylinder is lower that the caliper or wheel cylinder, gravity allows enough back flow to allow the caliper to retract and the pads won't remain against the rotor, same for the wheel cylinders. It adds petal travel and can allow brake pad chatter, noise. That's the theory.
  14. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,933
    637
    Gender:
    Male
    Occupation:
    Retired
    My m/c is under the floor and lower than the wheel cyl. and calipers. I tried with no residual valves and it was a no go. I can't pump the brake fast enough to recover stopping power, especially in an emergency. The proportioning valve didn't seem to make much difference unless I went extreme either way from center. On sand or gravel all wheels seem to lock up the same.
  15. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,803
    560
    Gender:
    Male
    Occupation:
    Retired
    So if you have a brake line that is for example 3' long, and you put a residual valve 12" away from the wheel cylinder or caliper. This is going to cause the 12" of line to maintain pressure. I get the feeling here that people are expecting a portion of the fluid in the remaining 24" of line to drain back to the master cylinder. If that happens, what replaces the drained back fluid that has left the 24" line. Air? Vacuum? I think I have to agree with @lincolnuT on this one.
    lincolnuT likes this.
  16. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,933
    637
    Gender:
    Male
    Occupation:
    Retired
    Mine are right at the m/c. So maybe 2' of line that could have a void.
  17. RPM
    RPM
    Expand Collapse
    Administrator
    Staff Member Forum Sponsor
    Oct 16, 2007
    5,073
    657
    You are thinking of a residual valve, which works like a check valve.
  18. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Duh! I confused the post... Sorry for misleading anyone!
  19. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    When I decided to go with them, I understood that they should be as close to the mc as possible for that very reason, talking about the residual valves.
  20. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    Wait, we were talking about residual valves, somehow things got jumbled, lol.
Share This Page
SSL Certificate
