one finger john
O.K. , obviously I was not clear in what I was asking. Until recently a person could buy from the NASCAR shops surplus parts for reasonable prices. I was looking at the differentials and they were advertised as having either a centered pinion shaft (dead nuts in the center of the diff), or having the carrier centered with the pinion slightly off-set. Which would be better in a roadster?
Also they gave you the choice of either a floating rear end (axles did not have a flange to mount the wheel) or a standard axle that the wheel bolted to. Obviously the floater would be safer if the axle broke. What are everyones opinions on these two options?
John
John
