Here is a little bracket we came up with. It will weld to your rear end housing and allows you to bolt the rear buggy spring to it. Has a 5/8 stud and 5 holes 1" apart so you can raise or lower the rear of the car easy. Also with this you can adjust the pinon angle with out binding up the shackles. These are available to fit several different rear axle tube diameters.
Also notice the new polished look on the steel since we bought our Burr King tumbler. It deburrs and polishs the metal, saving a lot of finish work when getting ready for paint.
