sschutze
I've started the restoration / Rebuild of my T-Bucket earlier than expected. My plan is to replace the front axle and spring (I'll be calling Jim @ Wintech today) with a piece that will lower the the front and fix the Camber issue; replace the rear spring with coil over shocks to lower the rear, and change the rear axle supports with either a radius rod setup or triangulated 4 link (I haven't decided); raise the engine on the frame to regain some ground clearance; re-route the wiring, brake and fuel lines; and chop the winshield frame by 4 or 5 inches. If I feel ambitious I might re-rout the steering column through the firewall to help with leg room, but I will probably have to replace the gear box and column for that. I haven't been able to ID the gearbox, but it doesn't look like the Vega or Corvair box's I have seen for sale. I'll get a picture and post it, maybe someone here can tell me what it's out of, or if it's worth keeping/reusing.
While I'm at it I'll clean up the frame (remove some unused brackets) and paint it, and maybe even paint the body.
Then I can sew up an interior and it should be like new. My goal is to give the car a lower stance for a more "hot rod" look.
