small bubbles in Gel coat
butch27
Been sanding on the body and have JUST A FEW air bubbles in the gel coat . I'll Dremel them out . What is the best filer to use on them. Bondo or a body putty in tube?
I add polyester resin to almost every batch of body filler I mix.
Keep a bit of resin in a squeeze bottle. When you mix up like a palm size amount of body filler, add a half dollar size squirt of resin. Mix all 3 together, the filler, colored hardener and resin.
You won't believe how creamy it gets. And spreads into pin holes like a glaze.
