Welcome to Our Community
Sign Up
Dismiss Notice
Speedway Body/Spirit frame
Discussion in 'Bodies' started by Steve McAfee, May 10, 2022.
  1. Steve McAfee
    Steve McAfee
    Expand Collapse
    May 10, 2022
    2
    0
    Gender:
    Male
    Hello all. New to this forum. Can someone tell me if a Speedway Channeled body will fine fine on a Spirit frame.
  2. Spanky
    Expand Collapse
    Jul 29, 2016
    3,087
    2,528
    Gender:
    Male
    Welcome, Steve! You will probably need to do some modification. I know right off, Speedway uses 1.5" x 3" frame rails, and Spirit is 2" x 3 ". However, making those notches in the body slightly wider should be no problem. Do you know the width of the body at the firewall, and the width of the Spirit frame?
  3. Steve McAfee
    Steve McAfee
    Expand Collapse
    May 10, 2022
    2
    0
    Gender:
    Male
    I have the spirit frame so I know that dimension. I just don’t know the measurement of the speedway body where it’s channeled.
  4. HenrysT
    HenrysT
    Expand Collapse
    Mar 12, 2012
    599
    227
    Gender:
    Male
    Occupation:
    Carpenter
    Well, what's the outside width of your frame? MOST T bodies are copies of the original T, so bodies from different companies have the same or similar dimensions excluding the stretched and /or widened bodies.
  5. Darinm
    Darinm
    Expand Collapse
    May 13, 2022
    6
    3
    Gender:
    Male
    Occupation:
    IT
    Hi, I have the speedway chassis and channeled body. The outside frame dimension is 27-1/2" If I measure the channel from inside the body, it's 28-1/2 outside channel to outside channel.
  6. Spanky
    Expand Collapse
    Jul 29, 2016
    3,087
    2,528
    Gender:
    Male
    Hm.m.m.m. . . my Spirit frame (made about 25 years ago) measures right at 26.5" wide, outside-to-outside. Sounds like your Speedway body would be a little wider (1 inch each side). That shouldn't pose a problem, assuming my frame dimensions are still current with Spirit's design.
  7. HenrysT
    HenrysT
    Expand Collapse
    Mar 12, 2012
    599
    227
    Gender:
    Male
    Occupation:
    Carpenter
    I made the CCR frame and that measures 26 1/2" also, I don't know who made my body, picked it up on Craig's list, and that measures about 1" wider than the frame which is perfect because it leaves 1/2" on either side for the fiberglass thickness when the body sits over the frame.
Share This Page
SSL Certificate
