I am working on coming up with a steering / axle/ ride height arrangement before i start dropping $$. My question is if i run the tie rod behind the axle but on top, how far behind the axle (approximately) will the tie rod be? i have a 28 grill shell that is on top of my front crossmember (actually about 3/4" forward) and i am trying to guess how far to put the spring behind to avoid tie rod to radiator interference.
Also wondering if there is a particular spindle design that would have the advantage of putting the tie rod closer to the axle.
I plan to do traditional steer with reverse corvair or sprint car style. I plan to have 9"+/- under the front rail, and need a 4" drop axle to get there, so i think tie rod under frame would take extended, heavily dropped arms which i can't find.
