Has anyone out there angled their steering column horizontally, to better center the steering wheel with the seating? Were you happy with it functionally? Was it a sore spot appearance wise?
On both of my streetrods the center of the column is at the center of the drivers seat. That is how I set up all my cars.
Just as I said in my post. Not to worry, will work fine like that.View attachment 11693
The above drawing shows the steering column angled at 5 towards the centerline...a compromise angle that is not set in stone.
How did you mount column to dash? Im in process of hanging my column now. Rpm stretch body and corvair box. Got pics? ThanksMy cowl is stretched, and with a BBC and a Corvair box fighting for space, my column is solid mounted to the dash and firewall with a support.
The box and column are connected with U joints, one inside the cowl and the other outside the firewall for foot clearance at the brake pedal.
As a result the homebilt column is directly aimed at the front axle and comes out thru what was originally a gauge hole in the dash!
I love the position myself, super comfortable, your hands just naturally fall to it while driving.
BTW...with the Corvair box a 12" wheel gives excellent leverage even when parking...on this machine anyway.
The way that I did mine was to mount a piece of 3/16" plate that acts as one of the body mounting points to the frame on both sides of the floor.. This plate goes over to the inside of the body and connects to a piece of 3/4" square tubing that connects to another piece of 3/4" square tubing that I glassed to the bottom of the dash. This piece of horizontal tubing behind the dash connects to a piece of 3/4" square tubing exactly like the left side. On the piece that you mounted behind the dash you can make whatever drop you may need to mount your column. This makes for a VERY strong mount. I might add that those two vertical pieces can easily made to "disappear" when you upholster the insides of the body.
Don't have pics available...but my cowl is stretched and a new firewall was built using 3/4" plywood and fiberglass.
The Column fits into a brace assembly that attaches to both the firewall and to the back of the dash.
Personally I would use a cross body steel support like the guys suggest if I were doing it over.
The column mount was there when I bought the car and IS strong...but you simply can't have the column mounting and the cowl area too strong!
You lean and pull on the column getting in and out and the cowl also supports the windshield.
Strong is good.
