Time to get some tires to build on. I am looking for suggestions on tire sizes This is where I am at in the build sbf at 500 + hp set up in the 3000 stall range. Running Turbo 400 trans. Rear gear around 4.10 speculated, have not gear yet purchased yet. Rear rims are CL 15 z 14 auto drags. Wanting to run a set of 14s that I have already on 14 x 7 CL rims on the front to make up for the loss in front axel drop. Frame was set up for 4 inch drop and I only have about 3 inch drop in front axle. I am looking at 31 x 18.5 rears right along with 29 x 16.5 and 29 x 18.5 now but very undecided at this point. I also have a set of 15 X 7 CL rims I could use on the front if need be but no tires for them. Just looking for some input before buying rears. I am needing to get them soon so as to get the mock up done and continue the build. I am trying to make a June roll out nut it might be too much to ask at his point. Just have to see how much I can get done from here. It might be nice to add a tire size and looks photo section to the site as well?
