Ted Brown
Just a quick thought from and old guy... Have someone Watch your T or car when you step on the gas pedal, when the car first moves at all, does it go up? or down? This will explain all about instant traction in a nutshell...
If it moves down, you are slow coming out of the gate and probably will get tire spin... Why? This setup requires the chassis to squat on the springs... With a lift (goes up) suspension, the bars have to lift the chassis (no springs required at that time) this puts all that lifted weight totally onto the tires and track surface... SO; Make the bars the correct length so as to be picking up the MOST weight without tipping the car over backwards... end of story PS, I heard a fellow tell someone that a Panhard bar allows a rear or front end to move in a side ways motion when the chassis moves up or down, it forces this movement, whether you want it or not, so make your Panhard bar as long as possible when using one...
