fordsbyjay
I was looking at buying some turn plates but couldn't stomach the $550+ price tag so I thought I would try and build a set first. I went down to my steel place and dug around in their dropped steel section and found an "L" section of 3/8" plate aluminum approx. 5 sq feet for $60. Then I went over to the hardware store next door and while looking for some other stuff I found some lazy susan turn tables rated for 1000 lbs. I picked two of them up for $27. Including 3 jigsaw blades I have about $93 in the project and about 6 hours of time.
Using a jigsaw I cut the round sections in a 12" diameter and the bottom plates are 14"x16". The bottom dimensions were really dictated by the size of material I had.
Using my degree wheel I made some 0, 10 & 20* increments.
Then I added a wire pointer to adjust the 0 mark once the car is on the plates.
Here it is with the bucket on it.
Here is a picture with my Smartcamber gauge.
