Welcome to Our Community
Sign Up
Dismiss Notice
what spindle and brake for tbucket build?
Discussion in 'Suspension' started by irishluck, Jul 3, 2021.
  1. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,791
    554
    Gender:
    Male
    Occupation:
    Retired
    In theory yes. In reality I believe the amount of change would be so slight that it's not worth worrying about, your mileage may vary.
    choppinczech likes this.
  2. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    irishluck and fluidfloyd like this.
  3. fluidfloyd
    fluidfloyd
    Expand Collapse
    Dec 29, 2008
    1,091
    290
    Gender:
    Male
    Occupation:
    Toy Builder
    If vertical height is an issue you can lay that bell crank flat or in the horizontal plane. Will also work above or below the rear end housing. I like a Watts Linkage much better then a panard bar especially when the bar length is short like most T Buckets are. Just another way to get from A to B.
    George
  4. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,212
    1,181
    Gender:
    Male
    Occupation:
    Retired
    OOOOH! I haven’t considered that! That opens a complete new can or worms! Thanks pal!
  5. PotvinGuy
    PotvinGuy
    Expand Collapse
    Staff Member
    Feb 22, 2008
    1,852
    770
    Gender:
    Male
    Occupation:
    Rack is Honda Civic in front crossmember. I cut off the Speedway panhard and made this contraption:
    ..it's based on a Watts linkage. Axle can move up and down and tilt, but no horizontal movement at all. IMG_0043.JPG
  6. AusBucket
    AusBucket
    Expand Collapse
    May 23, 2008
    402
    228
    Gender:
    Male
    Occupation:
    Photocopier Tech-Retired
    Very compact solution, I tips me Lid.
  7. Hackerbilt
    Hackerbilt
    Expand Collapse
    Dec 21, 2011
    355
    142
    Gender:
    Male
    Occupation:
    Collision Tech
    Panhard rods are meant to be set level. Level is dictated by the height of the axle pivot point of the bar being at the same height as the frame pivot point. The angle, shape or contours of the tubing between those points has no bearing on what is or isn't level.
    The J bar on a short bracket is no real difference geometry wise than the obviously wrong angled one shown here.
    J bars are useful to allow working clearance for the housing etc, but they still need to have the pivots at the same height to work as designed. Of course you can fudge it a little but the closer the better.
    mountainman likes this.
  8. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,212
    1,181
    Gender:
    Male
    Occupation:
    Retired
    The shape of the bar makes no difference. It’s the two end points that make the difference. The amount of movement on the rear is not drastic because of travel of the suspension is so limited. . The front with cross steer is more critical.
  9. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    You guys explained it better. The two mounting points as similar in height as possible.
  10. PotvinGuy
    PotvinGuy
    Expand Collapse
    Staff Member
    Feb 22, 2008
    1,852
    770
    Gender:
    Male
    Occupation:
    Quite so, ORF. Here is my Panhard:
    ..it spells BITEME in Farsi.
  11. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,488
    746
    Gender:
    Male
    Occupation:
    Retired
    The panhard rod is a bit squirmy but the mounting points are aligned. That’s the important part!!!
  12. MMC757
    MMC757
    Expand Collapse
    Apr 28, 2021
    101
    51
    Gender:
    Male
    Occupation:
    I get paid for what I know
  13. choppinczech
    choppinczech
    Expand Collapse
    Jul 2, 2012
    1,286
    985
    Gender:
    Male
    Occupation:
    Maintenance
    Indycars likes this.
  14. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,800
    1,306
    Gender:
    Male
    Occupation:
    retired.
    Nice video.
  15. fluidfloyd
    fluidfloyd
    Expand Collapse
    Dec 29, 2008
    1,091
    290
    Gender:
    Male
    Occupation:
    Toy Builder
    My Pleasure Sir! Also can be mounted in front of the third member on a bolt on bracket. Forgot to mention that earlier. Have Fun!
Share This Page
SSL Certificate
