Welcome to Our Community
Sign Up
Dismiss Notice
What type of steering box is this?
Discussion in 'Suspension' started by Edwin Hazzard, Sep 29, 2022.
  1. Edwin Hazzard
    Edwin Hazzard
    Expand Collapse
    Aug 31, 2022
    44
    9
    Gender:
    Male
    Hello. I bought this bucket and im trying to figure out what type of steering is used here. Im not liking the clearence between the header and the box. Any suggestions on what should be done with it if any? Thanks
  2. thebearded1
    thebearded1
    Expand Collapse
    May 1, 2019
    60
    61
    Gender:
    Male
    Looks like a corvair style steering box. You could try making a new bracket to mount the steering box at less of an angle but you'd have to add another u-joint or slide your steering column down.
  3. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,498
    1,104
    Gender:
    Male
    Spanky likes this.
  4. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,902
    921
    If it doesn’t hit, leave it. If it’s a problem, there are several ideas. Shim the motor mount to gain a 1/4” if it doesn’t negatively affect anything else, dimple the header, smaller tube headers, grind the box, re work the mount to lower the box... just keep in mind that everything likely affects something else.
    Edwin Hazzard likes this.
  5. Edwin Hazzard
    Edwin Hazzard
    Expand Collapse
    Aug 31, 2022
    44
    9
    Gender:
    Male
    Thank you sir! great ideas!
    fletcherson likes this.
  6. Randy Steel
    Randy Steel
    Expand Collapse
    Aug 25, 2020
    58
    63
    Gender:
    Male
    As mentioned above...looks like a reverse-corvair steering box for "traditional steering". I considered using this box on my T-bucket, but it made more sense to go with a a "Vega" steering box and use "cross-steering." I had to fabricate my own mounts to accommodate the gear box.
  7. Randy Steel
    Randy Steel
    Expand Collapse
    Aug 25, 2020
    58
    63
    Gender:
    Male
    It's been said that "cross-steering" has less steering bump vs. traditional steering. If you go with traditional, you may want to consider a pan-hard bar between your axle and the frame.
  8. AltBantam
    AltBantam
    Expand Collapse
    Aug 12, 2022
    61
    51
    Gender:
    Male
    Edwin. If you use cross steering, you will need a panhard bar. If you use a side steer with the 'correct' set up, a panhard is optional. Some people use side steering without the panhard with no problems. But it won't hurt if you have one as long as it is as long as you can make it. Looking at the image you posted, the reversed Corvair steering box has the pitman arm pointing down and appears inline with the tie rod end on perhaps a hairpin. That is the correct way to set up a side steering when not using 4 bar front suspension, according to what I've read.
  9. Edwin Hazzard
    Edwin Hazzard
    Expand Collapse
    Aug 31, 2022
    44
    9
    Gender:
    Male
    Thank you very much for the great information. It's much appreciated!
Share This Page
SSL Certificate
