Welcome to Our Community
Sign Up
Dismiss Notice
wind shield glass
Discussion in 'California Custom Roadsters' started by rubicon, Jul 26, 2016.
  1. PotvinGuy
    PotvinGuy
    Expand Collapse
    Feb 22, 2008
    1,654
    514
    Gender:
    Male
    Occupation:
    Is it the 11" or 14" tall frame? I had glass in my 11" frame and then went to the 14" frame to keep the bugs outa my teeth, and used Lexan. There are suppliers on eBay who will cut it to your spec. Comes in clear or 5% smoke and has a non-scratch coating. It weights a fraction of glass and will take a .44 magnum round without damage (I made that up). But NASCAR uses it, so it must be tough.
  2. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,706
    790
    No sweat! Hope it helps!
  3. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,706
    790
    Lol, I'd be willing to attempt to dispel the 44 magnum theory, it would give me an excuse to dust off the Blackhawk! A engine block lost the challenge.
  4. RPM
    RPM
    Expand Collapse
    Administrator
    Staff Member Forum Sponsor
    Oct 16, 2007
    5,048
    616
    Makes want get out my .44 and try it too.
  5. rubicon
    rubicon
    Expand Collapse
    May 28, 2007
    825
    239
    Gender:
    Male
    Getting off topic, as long as its about guns, I'm in. Guns and shooting are my first hobby.
    RPM and fletcherson like this.
  6. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,147
    823
    Gender:
    Male
    Seems like just some soapy water would work well and not harm the rubber in the long run.
  7. rubicon
    rubicon
    Expand Collapse
    May 28, 2007
    825
    239
    Gender:
    Male
    Quick question. Should I use just the liquid soap or soap and water mix?
  8. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,147
    823
    Gender:
    Male
    I would go with a concentrated mix of soap and water, you are not going to need much more than cup.
  9. rubicon
    rubicon
    Expand Collapse
    May 28, 2007
    825
    239
    Gender:
    Male
    Thanks
  10. rubicon
    rubicon
    Expand Collapse
    May 28, 2007
    825
    239
    Gender:
    Male
    Well I tried putting the glass in but ended up slicing the rubber tape up in the process. I thought I had plenty of soap on the rubber and frame but it was a very tight fit. I just ordered more rubber tape from CCR only its suppose to be thinner. Hope it solves my issue. If it does not has anyone tried caulking the glass in. I was thinking of putting couple of strip of rubber to center the glass then caulk the rest in. Any thoughts suggestions or comets? Maybe I should have broke the edge on the channel. That may have kept it from slicing. I will before I try the next one.
  11. 409T
    409T
    Expand Collapse
    Moderator
    Staff Member
    Jan 16, 2009
    1,647
    369
    Gender:
    Male
    Occupation:
    Retired
    I always have the glass company put it in with black rubber glazing compound. Let it dry overnight before taking it home (see post #8).
  12. choppedtop
    choppedtop
    Expand Collapse
    Jan 10, 2014
    1,767
    505
    Gender:
    Male
    Occupation:
    Retired
    I use the urethane from the glass shop. First, put the glass in place, the mask off what you can see. Remove the glass, put urethane in channel, then install glass. Let cure, and your done. Oh ya, mask off the exposed frame also. Urethane is not pleasant to remove. Trim excess urethane with sharp knife or razor blade before removing masking.
  13. rubicon
    rubicon
    Expand Collapse
    May 28, 2007
    825
    239
    Gender:
    Male
    Did you put anything in the bottom of the channel to keep the glass from touching the frame and how did you center the glass in the channel? When you started pushing the glass in, didn't it push the urethane down the channel towards the top of the frame? I know I'm asking lot of questions about this but, I'm trying to limit the amount of mistakes I could be making. The help you guys give is greatly appreciated.
  14. fletcherson
    fletcherson
    Expand Collapse
    Nov 7, 2014
    2,706
    790
    It sounds to me like the rubber tape you have is too thick. Also, lay it in the sun to make it plyable if it's rigid and use soapy water on the rubber as well as the frame. If you have an aluminum frame, the edges are likely razor sharp. It may be advantageous for you to de bur the edges before attempting it again. You can also smooth the edges of the glass with emery cloth if it's sharp. I do that if there are ragged edges because those are the areas that tend to initiate cracks, from by experience. It may be advisable to put tape on the glass to prevent any chance of scratching it and be sure to wear welding gloves or similar if you try that to prevent getting blood on your new glass, lol. If you decide to try eurothane, it comes in a standard caulking tube. You can get the eurothane at auto paint stores and quality auto parts stores. The 3m seems to work well, it works awesome to repair work boots too! Be sure to have some eurothane reducer on hand to clean up, it's resistant to most solvents. Also, make sure that you have everything as you want it, it's very difficult to remove once cured. From what I understand, thanks to the insurance industry, eurothane is the only legal adhesive to install glass, particularly windshields, in autos. Butyl is no longer acceptable. I'm not sure if it's available anymore or not. Eurothane is easy to use and definitely stronger, it's just harder to remove. If you decide to do it yourself, make sure that the glass is isolated from the frame so there is eurothane between it and the frame to prevent glass failure. I have used small pieces of vacuum line or any rubber material to assure that the glass is centered, also tooth picks and popsicle sticks are handy. Dry fit it first. When I put windshields in by myself, I measure the glass and the opening, then cut spacers to ensure that the glass is centered and test fit before applying the adhesive. That's about all of the "wisdom" lol, that I have to offer. Hope your second attempt goes better!
  15. 2old2fast
    2old2fast
    Expand Collapse
    Mar 25, 2010
    2,325
    484
    Gender:
    Male
    Occupation:
    sorta retired
    Being a little slow to notice , I just put your numbers in the calculator , the slot in your frame is only approx. 1/16" wider than the glass :eek:.. That's gonna be ruff to do even w/a liquid adhesive , let alone rubber ...1/32" per side ...wow!!
SSL Certificate
