Brucer
ok i have a goodwrench 350 4 bolt block, crank and rods.. all come out of a high mileage truck and it needs some lovin..
my proposed build.
freshen block
.030 bore block
.010 .010 crank
stock rods with good aftermarket rod bolts
chevy camel hump heads 64cc 2.02x1.6 valves, simple rework the heads valve springs and a 3 angle valve job..
federal mogul master kit
pistons federal mogul hypereutectics final compression 9.72 with 64cc heads with .040 head gasket
camshaft-summit racing brand
.488/.510 .292/.302 with 114deg lobe seperation angle...thats with 1.5 rockers, more than likely would go with 1.6's for a tad more lift and duration..
tunnel ram with 2x450 mechanical secondaries.. msd 6al ignition and..msd distributer(already have these)
tranny turbo350
stall 2800rpm
rearend 9 inch ford-3.90 gear ratio
this sound like a solid build?what kind of power? i'd guess a tad over 400hp
any of you guys thats had experience with T's for a while i would definetly like your opinions on practicality of this engine, mainly if it would be to much camshaft for a lightweight T..
thanks brucer
			my proposed build.
freshen block
.030 bore block
.010 .010 crank
tranny turbo350
stall 2800rpm
thanks brucer
