200-R4 Transmission fluid
Track T-4
I just finished replacing the leaking pan gasket on my 200-R4 transmission, now for the fluid. The trans has a mild shift kit. There is an external cooler so I probably did not drain alll of the fluid. I do not know what type/brand fluid the previous owner used in the transmission so a little concerned about the potential for switching to something different. Two questions:
1. If the fluid was synthetic before, what are the ramifications of switching to regular fluid and vice versa?
2. What is the best fluid to use in this transmission?
Thanks,
Bruce
You could go with something like Red Line, B&M, etc. They are supposed to compatible with all other fluids and be better, per advertised. Short of that, go with what is on the dipstick. Good luck,
What RR said!:thumbsup:
