I have an opportunity to pick up a complete Ford 9" from a 79 Bronco for my bucket project. Not sure if this will work or not. Any advice? I plan on using RPM coil overs if it makes any difference.
Putz, Where did you get that idea??? They just ride/drive a bit smoother with an open leg rear end in a light weight car, I have used a posi type third member for over 25 years with no problems in my Chy rear end...
Mean while back at the ranch. My chart shows that axle as 65.25 inches wide. Pretty wide for a T, I would think, but any 9" is good to have laying around. Most of the stuff will swap around.
