daw285
Hello every one,
I have a few questions for a TH350 expert. I asked Summitracing these questions but they were of no help to me (even though I’m trying to buy their parts). They keep wanting me to call in but whenI do they don’t seem to know the answers I want to know. If any TH350 experts can lend a hand in answering these questions it would be most appreciated. This is what I sent to summit:
I'm building a 1927 Ford Model T with a sbc 383 stroker. The engine makes about 500-550hp and is built to take a 300 shot of nitrous. This will be mainly a street car but I do plan on “getting on it” at the strip quite a bit. I'm running a th350 for a trany. I bought the trany used. It was used on a mid 80's camaro 1/4 mile drag car. It was rebuilt from what I can tell (red clutch disks and a few other things) but WELL used. The camaro was running a BBC and I'm guessing it had quite a bit of horse power. Since I knew little about the trany I decided to rebuild and beef it up a bit. This is my first transmission rebuild by the way. Most of the trany looks good except for a few things. First the Sun Shell has indents in the slots from the friction plates. I believe these indents, which are about a 0.026" deep, are from the transmission shifting very hard and with a lot of horse power on it. I have found a replacement sun shell in very good shape but it is about 0.25" thick and the one I have is only about 0.105" thick. First question, will this new sun shell fit my trany and work for me? They guy I bought it form said it would fit any th350.
Now for the questions that Summit will actually make money off of me with...The input shaft that's in the th350 has some deformed splines from the torque converter. They are deformed to the point that I want to replace it just to ensure I will not have issues from it in the future. It has become apparent to me the input shaft is part of the front pump. I see Summit offers two front pumps that I'm interested in. Here they are: http://www.summitracing.com/parts/TCI-313400/, and http://www.summitracing.com/parts/HUP-HP3230/. These are Low-Volume Pumps. Question 2, are these pumps suitable for my application? If so which is better for my application? I see the TCI has a bolt in stator and the Hughes has a cast stator. What are the benefits of each? What is the purpose of having a low volume pump? I would think a high volume would be better?...
Final question. I wanted to put a shift kit in the th350, or at least replace whatever the last guy had in it. After some research I decided to go with the TransGo Performance 350-1-2 which I purchased from Summit, http://www.summitracing.com/parts/TRG-350-1-2/. It seems to replace any and all of the parts the last guy could have changed out or modified in the valve body. I wanted a kit that would allow me to utilize my B&M Megashifter (http://www.summitracing.com/parts/BMM-80690/) and be able to be run in both automatic and manual shifting as needed. My question, did I choose the wrong thing? Should I have gotten a Manual/Automatic Valve Body such as summit item number http://www.summitracing.com/parts/HUP-HP3222/ or http://www.summitracing.com/parts/TCI-322200/ or http://www.summitracing.com/parts/TAC-23250/? Please advise and please let me know if there is anything else you think I might be missing.
Thanks for your time,
Dave
Dave
