engine24355
Thanks for the great information Fred! I have a CCR body also that I am putting a new interior in. Your pics are a huge help to me. Can I borrow / steal some of your designes...lol?
engine24355 said:Thanks for the great information Fred! I have a CCR body also that I am putting a new interior in. Your pics are a huge help to me. Can I borrow / steal some of your designes...lol?
engine24355 said:I need to get down your way and check out your ride.
Tbucit said:Fred, just a thought on the hinge placement. If you use the entire seat base and hinge that it could become a slight problem after the rest of the upholstery is installed. This is because of the padding that will be at the back of the seat. If the seat is hinged from the rear it will hit and you will not be able to rasie the seat bottom very high. And most times the lower seat cushion slides under the the rear and thus wouldn't be able to hinge forward. Several people I know and myself inculded have made a seperate panel (3/8 plywood) that the seat cushion is installed so it can be reomved and you can rasie the lid on the seat compartment. A couyple of pins will keep it from moving around if the fit isn't tight enough.Just a little food for thought.Randall[/quote.....Rick here.............When you have the fabric and foam in the car that seat fits pretty tight i have not had to do a thing and it doesn't slide but if you want to make sure mark off the bottom of the seat with it in place then glue some 3/4 ply blocks under the seat to hook in behind the riser. Rick
Rick said:Ya always gotta make sure things are right so a test ride is MANDATORY on all modifications!!!!!!!!!!!!!!!!
Geo27T said:Thats a good idea with the velcro. Where would you get some industral velcro.
