HELLRAISER79
Ok guys, help me out if you can. I've ordered a spirit 23t frame. I got it set up for a bbc so its 2" or so longer than their standard small block frame. Will i have to bend the steering arms to correct the ackerman angle or am i being too anal beings that its only 2" longer wheelbase? Do i even have to set the ackerman angle or do you think they do this? I got the whole stage 3 kit and then some. It uses 37-41 spindles and bolt on steering arms with the tie rod behind the axle(i believe, i havent got it yet). Also, while we are on the subject of the 2" longer frame, I have a sbc but it uses a long water pump. Thats why i ordered the big block frame(and for when i slip a big block in it one day). Correct me if im wrong but a sbc and a bbc motor mount would be in the same place on the frame, right? So even though i ordered it for a big block, i should be able to drop my sbc right in there. I wanted to have the option to run whatever chevy motor in this thing without having any clearance issues. Anyone else done this? went from a bbc to sbc or reverse? Thanks in advance.
Ken
Ken
