I am in the process of doing a door for my bucket as well. I have a TP body and the question I have is will your hinge work? I like the looks of it but have not been able to find it in your catalouge, probably doing something wrong on this da(*^(^& computer again. How do you attache the seat riser to the sides of the body might be interested in getting that as well looks like it would make the sides very strong without a ton of glass work.Here's a couple of door jam pictures. We use steel tube frameworks inside the Door bodies, all the bolts that pass thru the body are backed by steel plates and tied to the frame thru the floor. This way the fiberglass is being sandwiched between the metal and not carrying the stress. Over time this eliminates flexing and cracking.
The riser should support the side of the body that the door closes on , so keep that in mind.
Good luck
View attachment 5756View attachment 5757View attachment 5758View attachment 5759
