WMG
I am doing a complete rewire on the T. The old wires looked like a birds nest under the dash and there were a lot of wires going no where in harnesses. The original donor car was a 76 Camaro, according to everything I can find on the issue it should only be a one wire alt. however the dual plug had a connector in it, one wire was burnt off and the other went into a harness under the dash, it then changed color a couple of times and I am not sure where it attached or if it even did. Do I only put the one wire on and ignore the plug? OR?
