Hello everyone
This post is about what is involved in a bucket body in Australia.
In Aus we have the Australian Street Rod Federation - ASRF it is a national group that was instrumental in compiling the National Street Rod guidelines, the hot Rodders build bible.
The ASRF work with licensing depts in each state to help hot Rodders get their vehicles registered.
Each Aussie branch of the ASRF have technical inspectors who check off your work against the build guidelines over three seperate build stages. The inspectors are not engineers.
If you do something funky outside of the rules the inspector may refer you to an approved engineer for a report. As an example, supercharger requires engineering approval and at the final stage a functional test on the Dyno to prove you are not over 9psi boost.
In the case of fibreglass bodies the build bible refers the builder to some ADR’s which are design rules that all vehicles registered in aus have to comply with.
If your fibreglass body comes from production facility in aus it has to meet side impact rules for both strength of the fibreglass panel and in the case of doors the ability of the hinges and catch to hold.
In the case of my Koop de glass body I have to substitute no known fibreglass strength data with steel reinforcement. The reality is there is no more work to meet the rules than would have done otherwise to strengthen the body.
My doors do not have a jam as such so the way in my case to meet the side intrusion requirement is to have two burst proof catches per door, each catch opposite a hinge with steel tube in between.
The details for my body and side intrusion requirements have been sorted out with the technical advisory people first before anything is built. Inspection is just a formality once the works done.
Some people get bent out of shape with our rules but if you do the process in the right order it’s easy….build it first without consultation will end in tears.
In a month or so I will start on my body steelwork so I will set up a thread to show how this side intrusion stuff goes together.
Neddo
Neddo
