Francis Blake
Where does everyone have their battery? I am making a under floor bat box that the face of it will unbolt and the battery will be accessible with out cutting a hole in the floor. What do you think?
My new design for a T Bucket will also use a mount anywhere in any position battery, dry, and it will be mounted very close to the starter, to keep main cables to it as short as possible... Nothing will ever hang below the main frame again, nothing to get hung up on anything, including Radius rod brackets, the frame will be smooth the full length, just like a skid plate, all mounts can be mounted up higher with no real problems, this will also get the body lower, much easier to get in and out of... I don't know about you, but I need LOW now days, as far as stepping over goes... Real hot rods don't have doors... hehe
As far as interior room, more room for the feet operating the gas and brake is all that is needed, which can be had with careful planning, what is in between my legs and the passenger's legs does not matter to me, I would rather have no worries about important THINGS hanging down in harms way... I think seating comfort is also a must, and also can be had with planning...Ted that is how most rat rods are built, nothing below the frame rails. The only problem I see with these type cars is you have to mount the engine and trans real high in the chassis. Mounting the engine high really cuts down on interior room. Which is hardly any at all in a bucket.
The spun aluminum gas tanks mounted on the crossmember of an open car scare the hell out of me. I am pondering a different approach to the gas tank and will show and tell as (if) the idea develops.
I myself still have fairly long battery cables on my old design T Bucket... Everything works very well, except now days the cable costs about $7 a foot, so I am a cheap be$turd, I hate spending any more than I have to, for everything on the build, I can't make that cable, or I would do that also.. hehe I make every part that I can, and buy used whenever possible, because a T Bucket will never wear parts out like a normal everyday, heavier car...
So, keep all the copper wires to the smallest size for long runs, I will run 1 heavy wire #10 to the front and 1 to the rear for all the power, and run real small wire for grounding all the relays to turn things on and off with real light duty switches also... You can also stop any sparking at switches by using one way diodes as well... Things I will be using on my new build design...
Thanks, I will get it out there in my book I am attempting to write also, as far as batteries go, I used to use them for balancing weight to help get the car to get hold of the ground, as I am not a racer anymore, I will not be driving with more HP than is needed to get the job done, comfortably...Ted I am looking forward to seeing your new design, sounds like some unique ideas.
SIGN ME UP FOR THE BOOK!!! Is it anywhere close?Thanks, I will get it out there in my book I am attempting to write
My battery box is out of my 1950 Ford and is secured to the frame and the floor of the car.As usual Gerry, well done and a good point about the weight that requires a very secure mounting.
I have several really nice, fabricated aluminum battery boxes used in aircraft and I'll probably use one, but not with just a couple of bolts hanging off the frame. It will be well supported all around and protected from something contacting the terminals in an upset.
I am in a stage where I am testing a lot of new ideas, and making a full size plan that people can design out their whole car, just the way they want it to look and work, and chassis before starting to buy any building materials, besides body and knowing what engine and trans combo you want...SIGN ME UP FOR THE BOOK!!! Is it anywhere close?
One thing. Dont forget to make sure the battery is well secured. Thats a lot of weight to get loose. Mine is inside the frame rail sunk as low as I can. the distance from the alternator to the +ve is leas than 1 foot, due to the fact that my alternator is running off the diff pinion flange. Saves a lot of wire and allows me to use 50amp power cable like they use in ICE installations. Its real pretty wire as well.
[attachment=4795:bat 1.JPG][attachment=4796:bat 2.JPG]
Gerry, I too run the alt off the driveshaft. Do you use a v-belt or what? Drive ratio? What speed does it start charging? Mine is a GM CS100, v-belt now, but have a Gilmer belt and pulleys ready to go in. My drive ratio is 3:1 and it starts charging about 20 MPH, sorry, 32 KPH. I use an Optima yellow-top battery for fast charging and deep discharge.
