When I first built my car I used a "fuel injector sizing" site to pick 36lb injectors. But I noticed that the idle injector duty cycle (as indicated on the FAST handheld) was less than 1% (it fluctuated between 0 and 1 because the handheld only displays to the nearest percentage). I figgered the mildly rough idle and rather poor off-idle response was due to the injectors being too big. So I swapped them for 24# units. Here is with the wiring disconnected:
...and with the left log off:
The log and injector assembly:
Here's the new 24# injector:
..with a nicked O-ring...ack!
How did this happen? And how did I find out? When I put it all back together 3 of the injectors were spraying from the top end. Looking at the fuel rails:
I could see that the rail had drilled holes with sharp edges, and the O-rings were being nicked while coaxing the injectors into the rail. So I used some fine sandpaper to ease the edges, used plenty of grease, and no more leaks. And here we are buttoned up with the wiring still exposed:
Went for a ride. The idle duty cycle is now 3-4%, cruise is about 7% and WOT is 40%. That's with the blower undriven. Idle is smooth and throttle response is smoother too. Now I need to find a big open space to test with the blower engaged.
What have we learned today, boys and girls? Picking the right size injector will make your ride happier. Too big and your motor will be rough. Too small and you could lean out at WOT. And don't be tempted to put big HP numbers in the sizing calculators. I used 500, which I will never see.
