Screaming Metal
It Probably has a Steel crank then with good rods....look up the # on the block for verification purposes....Well my 454 came out of an early 80's dually so it may have a steel crank already. I'll know when I change out the oil pump before putting it in the car.
If thats the case, all you'd need is to get the crank doublekeyed, add asteel hub or run a fluiddampr balancer and your blower kit
