There was a big discussion on the HAMB about these motors depends on what 4 cylinder Mercury marine motor you have for intake and exhaust .They had one that uses a Ford big block cylinder head which I think is the 3.0 motor,The 152 motor you can use car intake and exhaust headers on it's the same or cut the water jackets off the marine intake to pretty it up.all the boat motors have more stock horse power than it's land locked equals in cars.I dragged hom3e a junk boat just to get the guages and 140 hp Chevy 4 popper out of it.I will be mating the boat motor to an s10 5 speed trans and s10 4x4 rear in my next build(next build?I didn't just say that did I!)donsrods said:I've got a 3.0 liter Mercruiser engine sitting on the shop floor that I scored at work one day. I have no idea what project I will ever use it for, but it would be cool in a little track T. Biggest problem I have found is getting an intake and exhaust manifold for these engines. The boat motors had a water cooled exhaust/intake manifold setup, so that can't be used. I have done some research, and Clifford and others don't make one for this engine. But if I ever do use it I'll fab up an intake and some headers to use.
The one thing you want to look at with a marine engine that was used in salt water is possible rust through in the cooling passages. A fresh water motor is a whole nuther animal and doesn't have those problems so much.
Youngster said:Dose anyone know if the cam and rollers from a later motor will work in the earlier or boat motors??
bobscogin said:You can use the marine flywheel if it's drilled for a clutch pressure plate. Not all of the marine engine flywheels were drilled with that pattern. If yours is drilled, your good to go. If not, drill it or use a neutral balance automotive flywheel.
Bob
