akzale
I have an aftermarket wiring harness, and there is a wire from the fuse block that goes to the brake switch. This wire provides power to the pressure switch I have in the brake line. I also have an Ididit steering column with a wire harness. One of the wires in it is labeled for the brake switch. I understand this will allow the brakes to blink with the directionals. My question is ..... how do I wire these 2 brake switch wires up? Do I need both wires connected, and how/where do they go?
If you haven't figured it out yet, I suck at wiring!!
